Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - radiator hose
Thread: radiator hose
Old 12-09-2003, 02:20 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Was the pulley you installed the crank pulley?/ Accessory pulleys?/ All pulleys? to under-drive you need a smaller crank pulley or larger accessory pulleys or a combination of the same. If you changed accessory pulleys and the belts is too long, those are over drive not under-drive. If you changed the crank pulley for an under-drive, that would result in your too-long belt problem. Regardless, car pool to work until you can get to the parts shop and get the proper length belt. Much cleaner than new bracketry.
