Radiator hose flattens when revving engine.
Just installed 406 in my Cutlass, got it started and let it run for a min to allow time to heat up. I noticed only when I raised the engine both the top/bottom radiator, and heater hoses would swell then flatten out. I have swapped thermostats and tried 2 different radiators, but still having the same problem...
The make molded hoses that are made for exact model of engines and some flexible hoses that have a wire wound in a spring like shape that are inside the rubber hose. They keep the hose in shape.
Now another question: What would be the symptoms of having too small a radiator? |
The return hose at the top front of the engine to the radiator is normally under pressure and will expand somewhat as revs, thus hydraulic pressure in the engine rises above hydraulic pressure in the radiator. If the throttle is suddenly closed from fairly high RPM you might see this hose and the heater hoses expand and contract some as hydraulic pressure surges form in the engine. I use the term "hydraulic pressure" to denote a difference between pressures induced into the coolant by the actions of the pump against the restrictions of the engine's cooling passages and the regulation of the thermostat. This is different from what one normally thinks of radiator or coolant pressure which is caused by the combined effects of heat expanded coolant and its vapor pressure which are what the pressure cap is managing. Bogie |
If you have a spring in the hose it goes on the bottom hose, the top hose does not need one. Try burping the cooling system, run it with the cap off for 10 minutes, let the thermostat open all the way and the coolant circulate for a while and get all the air out. When the thermostat first opens up with the cap off the radiator will push about a quart of coolant out onto the ground, then the level in the radiator will go wayyyyy down. Top it off and repeat one time and it should be free of air.
I'd also try a new radiator cap, I've never seen all the hoses get sucked closed but if the top one is going flat it's usually the cap.
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| 1973 Chevelle Malibu Engine Rebuild (pics 56k no) | Malibu73 | Hotrodders' Lounge | 39 | 11-04-2008 12:37 PM |
| setting points on sb chevy | frackster66 | Electrical | 14 | 03-22-2008 11:33 AM |
| 1985 C-6 truck tranny, no engine braking effect | fast68 | Transmission - Rearend | 40 | 02-04-2008 05:55 PM |
| Is that an air tool or an F1 engine revving? | coldknock | Hotrodders' Lounge | 5 | 05-11-2005 04:49 PM |
