Radiator Hose question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2007, 03:31 PM
My 2 hoses top and bottom of my Rad are a bit big, not much but I want to take up the slack! I am going to cut a piece of tire tube, any better suggestions? Great site as always, Dana
Old 03-24-2007, 03:38 PM
DeathRattle's Avatar
Some Punk Kid
I am assuming your talking about the inside diameter and not length?
If so how much slack are we talking about? If its that generous of an amount they make rubber reducers that will make it fit correctly for a more permanent fix.
If its not enough to put a reducer on I think your idea will be fine.
Old 03-24-2007, 03:43 PM
poncho62's Avatar
Wiki Edits: 5
Get the right size hoses................With a piece of rubber in there, they are liable to slip off, leak....or both.
Ontario Rodders
Old 03-27-2007, 10:45 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
I've bought hoses that came with a short rubber sleeve to fit more than 1 application.Never had a problem.
Old 03-27-2007, 11:36 AM
The rubber reducers do work, they use them at radiator shops. If you're going from a modern V8 to an older style rad where the neck sizes are different they come in handy.
Barry
Old 03-28-2007, 09:43 AM
There are several different sizes of hose bushings which make it much easier to use a hose that is good except for ID size.
Old 03-28-2007, 01:19 PM
GMCTRUCKS's Avatar
Loose hoses
I agree with poncho62 buy the right size why chance it after you put all your hard earned money then for it to over-heat I wouldn't forgive myself with that were to happen and I knew about the problem.
Old 03-31-2007, 01:44 PM
I made the mistake of using silicone between the rubber bushing and rubber hose end on a coolflex hose. On a hot Texas day, bumper to bumper traffic, the hose backed off the bushing. Bad day. Bill
Old 03-31-2007, 03:52 PM
Re: Radiator Hose question
When I tried to replace the hoses on my rod I went down to the local auto store and they let me search through their whole rack of hoses. I probably looked for an hour before I got the right set. It looks and works a whole lot better when they fit the right way.
Old 03-31-2007, 04:00 PM
DesertrusT's Avatar
Jailbar Revolutionary
you nailed it hotcoupe, you have to persuade them to let you search out your own hose. they'll try to convince you that they can find it for you, just take the old hose back and compare. you will get the right hose every time.
Old 03-31-2007, 10:04 PM
Sometimes a bushing is the best choice, if you're in a deadline situation, if the parts guy isn't that cooperative, if you want to ride today. Bushings should be installed dry, no lube and no sealer, just slide it in the hose and slide the hose on the water neck or radiator neck, then clamp in place as usual.
There is no danger in using a bushing.
Old 04-01-2007, 09:09 AM
39, Another thought,FWIW, is to make one if you can't get the correct fit. I bought a 180 ubend, stainless, beaded the ends and welded it with my mig- I had a shape/size I couldn't seem to match up. Bill
Old 04-01-2007, 09:32 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
This might help you guys that like to browse through the hose rack.
Dayco dimensional lookup
All you need is an approximate total length, and the ID of each end.
Armed with the resulting list of choices ... you can view the pictures for the correct bends.
When you get dow nto the "short list" ... you can phone around to see who has one in stock.
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
