-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   radiator hose reducer (http://www.hotrodders.com/forum/radiator-hose-reducer-141349.html)
GMR 07-02-2008 07:32 PM
I picked up a junk yard radiator from an '89 Cadillac to use for breaking in a newly rebuilt sbc 350. The Cad radiator upper hose fitting is 1 1/4" and the lower is 1 1/2". The motor upper is 1 1/2" and the lower 1 3/4". If I use Chevy hoses from a place like Napa, I'm thinking I'll need a reducer for both top and bottom. If that's true, where can I find them - hardware/plumbing store - or someplace else?
hotrodhill 07-02-2008 07:57 PM
hoser
A lot of radiator hoses have different sizes on either end. Go to a parts store that will let you go hose hunting and see if you can match up the hoses you need, good luck , Tom.
JeffB 07-02-2008 09:24 PM
Most radiator shops will have them.
joe_padavano 07-03-2008 08:28 AM
You can also usually just use a short section of straight radiator hose with the correct ID and OD as a bushing.
ScoTFrenzel 07-03-2008 09:03 AM
exhaust pipe reducer bushings are perfect
joe_padavano 07-03-2008 09:22 AM
I guess I wasn't clear. What I was suggesting is that a short section of straight hose (about 2" long) is used as a bushing. Slide this short section of hose over the fitting on the radiator then slide the real radiator hose over this short section and put a hose clamp on the whole thing. The short straight section just acts as a spacer between the fitting on the radiator and the ID of the full hose. I've done this before and it works fine.
ScoTFrenzel 07-03-2008 09:31 AM
:thumbup: More than one way to remove the outer covering from a feline. :thumbup:
GMR 07-03-2008 06:18 PM
Thanks fellas, I'm sure I'll get one of your options to work.
Henry Highrise 07-03-2008 06:31 PM
I have bought rubber reducers before and I bought them at NAPA.
GMR 07-05-2008 08:43 AM
Thanks Henry.
lemondana 08-10-2008 01:21 AM
Radiator Hose Reducers
Goodyear sells radiator hose reducers. 58981 for 1 1/2"ID to 1 1/4 ID, 58982 for 1 3/4" ID to 1 1/2" ID, 58983 for 2"ID to 1 3/4" ID, 58984 for 2 1/4"ID to 2" ID. Just find someplace that sells Goodyear products, I'm sure they will have to order them though. Myron
