radiator hose reducer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2008, 07:32 PM
GMR GMR is offline
I picked up a junk yard radiator from an '89 Cadillac to use for breaking in a newly rebuilt sbc 350. The Cad radiator upper hose fitting is 1 1/4" and the lower is 1 1/2". The motor upper is 1 1/2" and the lower 1 3/4". If I use Chevy hoses from a place like Napa, I'm thinking I'll need a reducer for both top and bottom. If that's true, where can I find them - hardware/plumbing store - or someplace else?
Old 07-02-2008, 07:57 PM
hoser
A lot of radiator hoses have different sizes on either end. Go to a parts store that will let you go hose hunting and see if you can match up the hoses you need, good luck , Tom.
Old 07-02-2008, 09:24 PM
JeffB's Avatar
Most radiator shops will have them.
Old 07-03-2008, 08:28 AM
You can also usually just use a short section of straight radiator hose with the correct ID and OD as a bushing.
Old 07-03-2008, 09:03 AM
exhaust pipe reducer bushings are perfect
Old 07-03-2008, 09:22 AM
I guess I wasn't clear. What I was suggesting is that a short section of straight hose (about 2" long) is used as a bushing. Slide this short section of hose over the fitting on the radiator then slide the real radiator hose over this short section and put a hose clamp on the whole thing. The short straight section just acts as a spacer between the fitting on the radiator and the ID of the full hose. I've done this before and it works fine.
Old 07-03-2008, 09:31 AM
More than one way to remove the outer covering from a feline.
Old 07-03-2008, 06:18 PM
GMR GMR is offline
Thanks fellas, I'm sure I'll get one of your options to work.
Old 07-03-2008, 06:31 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I have bought rubber reducers before and I bought them at NAPA.
Old 07-05-2008, 08:43 AM
GMR GMR is offline
Thanks Henry.
Old 08-10-2008, 01:21 AM
lemondana's Avatar
Radiator Hose Reducers
Goodyear sells radiator hose reducers. 58981 for 1 1/2"ID to 1 1/4 ID, 58982 for 1 3/4" ID to 1 1/2" ID, 58983 for 2"ID to 1 3/4" ID, 58984 for 2 1/4"ID to 2" ID. Just find someplace that sells Goodyear products, I'm sure they will have to order them though. Myron
Urethane Clearcoat Reducer DGW Body - Exterior 44 11-15-2007 09:13 AM
Clear coat reducer? magnoman Body - Exterior 8 07-01-2007 03:42 PM
need help with a 12 v to 6 v reducer oldguy829 Electrical 32 08-21-2006 05:02 PM
Where to find AcrylicEnamel Reducer and thinner on the net? lexicon1 Body - Exterior 1 04-11-2006 05:51 AM
reducer 6speedwagon Body - Exterior 10 05-07-2004 04:17 AM
