Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - radiator hose reducer
Old 07-03-2008, 10:31 AM
ScoTFrenzel ScoTFrenzel is offline
Originally Posted by joe_padavano
I guess I wasn't clear. What I was suggesting is that a short section of straight hose (about 2" long) is used as a bushing. Slide this short section of hose over the fitting on the radiator then slide the real radiator hose over this short section and put a hose clamp on the whole thing. The short straight section just acts as a spacer between the fitting on the radiator and the ID of the full hose. I've done this before and it works fine.
More than one way to remove the outer covering from a feline.
