Radiator Lower hose que. on 350 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2008, 08:33 AM
I have a 1951 style Radiator that has a smaller lower outlet and having trouble finding a hose to stay tight, any suggestions, Only need a shaped "L" hose about 18 in. each way! Ideal would be a flex type hose but do need a smaller size on Rad end! Thanks again, Dana
Old 07-20-2008, 08:38 AM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
They make inserts or hose adapters for this. I have the same thing on my upper hose. It is basically and smaller diameter hose that slips over the neck, trim down to needed length, and then slip hose over it. I have had zero leaks. Not real sure where they may be purchased, mine came with the metal hose kit from Summit Racing.
Jason
Old 07-20-2008, 08:41 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You can get hose adapters at NAPA...I used one on the lower hose on the 30 Ford coupe that I built with a 350sbc.
Old 07-20-2008, 10:58 AM
Thanks for the fast response!, Dana
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
SF oil???? n-gin Engine 6 07-09-2008 02:37 PM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 06:55 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 08:01 PM
