radiator mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2009, 11:45 PM
radiator mounts
I need to mount the radiator in my 1927. T, it has a model A crosmenber in the front, I have a custom 4 core copper radiator with brass tanks witch fits in the orignal T shell.
can some one poast some pics of how they have mounted there radiator? or should it be solidley mounted or on rubber mounts?
Old 09-15-2009, 07:04 AM
cboy's Avatar
Last journal entry: Finished
There are a number of variables effecting how you mount...is the radiator in front, back or on top of the cross member? Also, since it is a T, do you want/need the struts/supports running up the the windshield post? Also other factors involved.
In general I would say the radiator can be bolted solidly to your frame and brackets, no rubber cushioning is necessary.
I doubt this will help much be here is how I've mounted the rad in my sedan delivery. Might give you some ideas.
Always learning...and sharing what I've learned.
Old 09-15-2009, 07:58 AM
Wiki Edits: 27
t radiator mount
It depends on how rigid your frame is. the original T frames had a lot of twist and flex on rough roads so they were mounted with small coil springs. parts companies that deal with restoration parts still have them.. Check out snyders or MAC or go the the MTFCA and they have a list of parts companies... If your radiator has the original T type ears on the bottom you can go original or rubber mounts. I used the small shock absorber donuts on one of mine. If you use original type bottom only nounts you should have a brace from the radiator to the firewall or a top hose that won't allow the wind to push it back into the fan. My son had a rad like CBoy's with the side flanges and used the upright angle irons, It depends on your radiator and how much space you have, for T information check out tbucketeers or The National T Bucket Aliance.
Old 09-15-2009, 08:16 AM
cboy's Avatar
Originally Posted by timothale
It depends on how rigid your frame is. the original T frames had a lot of twist and flex...
Good T-specific info, timothale. I would defer to our observations about the use of cushions or rubber mounting for any flex-chassis application.
Old 09-15-2009, 09:06 AM
302 Z28's Avatar
The OEM way a radiator is mounted to a 33-34 Ford uses rubber cusions and a spring and is mounted directly to the frame.
Vince
Old 09-15-2009, 04:37 PM
Here is a pic, I will take a closer one when I get a chance, Don't be fooled by the chassis horns, its not a model A chassis but I welded A chassis horns on.
I would like to have stays running from the radiator shell to the firewall, as I am not using a bonnet
Name:	T. Rod 003.jpg
Old 09-15-2009, 04:43 PM
I was thinking of riveting some brackets to the side like your radiator but I don't think the steel strips up the side are up to it on mine
