Radiator overflow system - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2012, 01:39 PM
Bobs36ford's Avatar
Last journal entry: Bobs 36 Ford
Hi... My 36 Ford w/ 5.7 chevy motor has no radiator overflow reservoir system.
Every once in a while I'll notice antifreeze on my garage floor and its coming from my overflow pipe.
My question is do i need a overflow reservoir system or is it something else.
I changed the thermostat (2) times and finally removed it entirely. The engine does not over heat.
Bob.
Old 05-27-2012, 02:12 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What i did was got the reservoir and it could be used either way, with or without the vent, i went with the vent in top so it would recirculate works great for me , when it does puke it re-circulate back through the radiator not on the ground.
Cole
Old 05-27-2012, 02:16 PM
In the old days Bob, all radiators had a fairly large top tank. My 36 Ford radiator has about a gallon or so tank on top. The reason for the large upper tank is the antifreeze/water will expand a significant amount when the engine gets warm. That is why new cars have a cold and hot line on the overflow tanks. If your engine does not overheat leave the coolant about one to one and a half inches down so it has room to expand and it will quit dripping. if it doesn't have room to expand though it will puke....... guaranteed.
Old 05-27-2012, 09:24 PM
Bobs36ford's Avatar
Radiator overflow
Thanks for the info.
Bob
Radiator puking out the overflow bottle Kilrcady Engine 8 05-28-2010 02:13 PM
Radiator Overflow Tank S10 Racer General Rodding Tech 2 04-08-2009 07:36 PM
radiator overflow tank yragat Engine 5 05-24-2007 05:55 PM
radiator overflow tsw5013 Engine 12 07-27-2005 12:41 PM
Radiator overflow tank?? wougelafive0 Engine 7 12-03-2003 11:04 AM
