Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - radiator position
Old 06-23-2013, 06:00 PM
evolvo's Avatar
evolvo evolvo is offline
Originally Posted by V8Square View Post
Thanks for the replies. I always thought that the height of the radiator was an issue, also. So, the way I have my fan, on my radiator, is on the engine side. Is that OK, as I want to ran a/c in my project and would need to have the condenser in front of my radiator unless I mount it somewhere else with it's own fan. Thoughts, suggestions.
The height of the radiator is fairly loose, you just don't want it's top lower than the water pump (I can't imagine anyone doing this!).
By the way, my fan is a puller type.
IMO puller fans are more efficient, plus it certainly makes mounting the A/C condenser much easier.
Are all stock radiator hoses the same length on a small block 350? I know that must sound like a dumb question, but I had to ask.
I really doubt that they are.
