radiator replacment in 1990 3/4 350 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2007, 12:04 AM
hello,
requesting any helpful suggestions on replacing a radiator in a 1990 chevy 4x4 3/4 ton pickup. The fan blade came off while driving the truck , and it ate up the radiator. Will need to replace the top and bottom fan shroud, pulley on the water pump maybe. and also the fan clutch. I want to work with my 16 year old son on this project. Thanks dandan42
Old 03-28-2007, 04:02 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
You might check out the water pump too if it was that horrible of a wreck
The rad & fan clutch I would replace new all the rest I would hunt the bone yards.
Better check the hoses too!
Good luck!
R
"SlowRide66"
"Illegitimis non carborundum"
Old 03-28-2007, 04:37 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
LMC is a good source for your truck parts. I've used them quite a bit for my truck parts. As far as a radiator...most have the plastic side tanks. I think I paid $189.00 at AutoZone for mine.
Old 03-29-2007, 06:28 AM
Rob Keller's Avatar
Wiki Edits: 38
4 core aluminum W/ plastic tanks limited life time warranty from Car Quest $139.+tax
R
"SlowRide66"
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 07:43 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 09:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 06:46 AM
1990 Chevy van 350? Mollard Engine 9 10-29-2004 09:55 AM
