Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Radiator, (set me straight)?
Old 02-23-2009, 09:19 PM
kleen56's Avatar
kleen56 kleen56 is offline
Not sure what your asking here? Are you wanting to replace the old radiator with a new one or an aftermarket, or from a different vehicle. Different radiators will work. The critical part is how many rows of cells are in the radiator, size (width and height). Several people choose aluminum radiators for their cooling capabilities. As long as the 360 is not modified, bored, stroked and you name it, you should be fine. If you also concerned with cooling, mount some electric fans to the inside of the radiator to draw more air.
