Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Radiator, (set me straight)?
Old 02-24-2009, 07:45 PM
kleen56's Avatar
kleen56 kleen56 is offline
39, the key is surface area, so larger radiator of course will cool much better than smaller ones. More air, the cooler the radiator can cool. Radiators come with what is known as 2 row or 3 row and even 4 row radiator cores. 4 Row is the best for high temperature driving and cooling. Get a radiator that fits size wise and you'll be fine with a 3 row radiator. Make sure the necks on the upper tank and lower tanks will work with your engine. (lower hose on left or right side of engine and location of the upper hose. etc. Good luck.
