Radiator support rod help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2012, 02:28 PM
Last journal entry: Getting there....I think
Any tutorial on installing radiator support rods and brackets? Pictures? I need to drill the holes for mine and weld brackets on the radiator.
Thanks guys!
Old 06-18-2012, 02:56 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Well furst get yerself some rod at the steel yard..I suspect 1/4 or 5/16 will be fine...make a bracket out of some square tubing to weld to the firewall with a hole in it..then make two more to attach to the rad support..weld thos on..good to go..then cut your rod to length and thread the ends for nuts and install them..this ought to keep ya occupied for a couple of hours in the shop.. About a one or two beer job...
Grins
Sam
Old 06-18-2012, 03:08 PM
What kind of car? There are factory brackets that go at the firewall on most every car I have seen, do you have them for yours? Then at the front, depending on the make model and year there are brackets that mount to the fenders or rad support others have them built into the radiaor, what kind of car do you have?
Old 06-18-2012, 03:31 PM
fenderless&hoodless 36 chevy truck. just got it back from the paint shop. the firewall has no holes (welded flush at paint shop). been looking at pictures online as to where i should mount them.
Old 06-18-2012, 03:37 PM
i recently bought stainless rod brackets for a 32 ford for it
Old 06-18-2012, 04:45 PM
There isn't going to be any kind of tutorial on doing it because you have a miss match of stuff. Can you see where the old ones were mounted from the back? I seriously doubt that they finished off and painted the back side, you should be able to see exactly where they were.
That being said you want to put them where it's pretty strong. If you can't put them right where they were for some reason you need to put them near folds in the metal or near where to panels are welded together or something that makes it a little stronger.
If you can't find a place take some photos (full frame of the entire firewall inside and out). So we can give you some tips.
Old 06-18-2012, 04:54 PM
i wanted to place them more toward the middle like how alot of 32 ford coupes are. maybe ill weld plate behind the firewall for extra support
Old 06-18-2012, 05:07 PM
Is this truck fenderless or hoodless? Because to align the hood and fenders you may need those rods out further apart just as they had it when new.
Old 06-18-2012, 05:21 PM
like i stated a few posts back, yes it is fenderless and hoodless so it wont matter
Old 06-18-2012, 05:32 PM
Well there you go, there isn't much to think about then. Well supported at the firewall and on the radiator so it is held steady. I would put it at a "V" shape narrower at the rad but many cars didn't do it.
Old 06-18-2012, 05:36 PM
sweet thanks!
radiator support redvassilis Engine 0 02-15-2012 10:33 AM
67 Mustang Radiator Support Stangman196700 Body - Exterior 7 11-07-2008 02:28 PM
Radiator support came to pass Body - Exterior 2 09-15-2007 11:36 AM
70 nova radiator support backyard71nova Body - Exterior 7 08-04-2007 11:38 AM
bent radiator support erockschevy General Rodding Tech 10 11-01-2004 04:24 PM
