radiator tunnel - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2006, 09:05 PM
radiator tunnel
how important is it to have your radiator blocked off from the rest of the engine bay? does it increase performance? or does it just prevent the engine from exploding?
Old 01-17-2006, 09:11 PM
Jmark's Avatar
Sorry, but I have no idea what you are refering to or asking about? Can you elaborate some?
Mark
Old 01-17-2006, 09:25 PM
I believe you are talking about a fan shroud? I don't know about it keeping your engine from exploding, but it will greatly increase the ability of the fan to pull air across the radiator and help with cooling.
Old 01-17-2006, 09:32 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
thats what I was thinking. BTW, it's good to see someone else from GR on here pm me sometime.
Old 01-20-2006, 10:09 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
YES. You want to make sure all the air coming in the grille passes through the radiator, not around it, over it, or under it. You also should seal from the bumper to the radiator bottom so that when idling the hot 200* engine compartment air will not be drawn back into the front of the radiator. Don't forget to seal from the radiator top (core support) to the hood. Most assembly line cars had seals there.
A fan shroud and good thermostatic fan clutch will insure that all the airflow possible will be drawn through the radiator.
