Radical rat rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2006, 06:30 AM
Last journal entry: Model A finally starts to get it's motor
Radical rat rod
I am just starting a new rat rod. I am new into rat rodding so some advice would definately be great. I want to suicide the front axle, Z the backhalf, and of course put some better breaks. I am on a tight budget. I barely talked the wife into this. I just bought a 30 model a pickup frame, bed, hood, grill, and, cowl. I am gonna use a 283 that I have sitting around and also a three speed manual. Any advice on upgrading the brakes. Also I want to put a 4 link rear end. I have a ford 9" which I hoping is the right width.
Old 02-14-2006, 06:55 AM
cboy's Avatar
Last journal entry: Finished
Welcome to HR.Com. You have come to the right place to find virtually any answer you need for building up your '30. At this early stage my advice would be to spend lots of time exploring the Knowledge Base, the Project Journals and using the "Search" function here on the technical forums (there are many many discussions regarding brakes). Then, as specific questions come up which have not already been answered or shown, fire away in the appropriate forum and I'm sure you will get plenty of help.
As far as specific advice on your new project, it's may not be glamorous - but you'll probably want to start by boxing your frame. Even though the 283 isn't going to put out numbers like a blown big block, you want to make sure that tired old frame hangs together for you and stays straight.
Dewey
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 02-14-2006, 07:47 AM
Simplicity's Avatar
Welcome
Yes there is tons of great people here, with lots to offer.
Just start reading!
Old 02-14-2006, 07:52 AM
redlightning's Avatar
Welcome to the forum.I would highly recommend you look at cboy,s journal.
Junkyard Motors.. Zartan Engine 20 07-08-2011 07:52 AM
Rat Rod? Silentlion_69 General Rodding Tech 97 08-13-2009 07:34 AM
Rat Rod - where to start? jasonbeamstudios@mac Hotrodding Basics 4 12-19-2005 07:35 AM
Rod ratio RobbieRat Engine 16 11-29-2005 06:52 PM
?? Bore Sizes ?? ss crazy Engine 2 10-03-2003 02:51 PM
