radio wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2006, 11:41 AM
67purplebeast's Avatar
radio wiring
I would like to install a radio but I am having a hard time finding the wiring. How do I go about this or how do i find out if this was a radio delete car. If it is, how do I installsound system? Thanks
Old 08-10-2006, 12:06 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You should have an accessary position on your fuse panel.....you can get your power from there.
Old 08-10-2006, 01:49 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
What car is this? Does it have speakers currently installed?
Typically, for newer radios, you will need a constant power feed (for the clock / memory) and a switched power feed (as Henry stated). Simple enough to run from the fuse block if you need to. Then ground it to a good location and wire up your speakers.
Old 08-10-2006, 05:29 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Well, to install a radio in a Kabota Tractor..you must weld brackets to the dash panel..bolt and strap the radio to it , run primary and secondary power and ground to the unit , and duct tape a speaker to it as well as a long wire antenna..Does this help at all.....??
I Think not...
Without information, that's the best answer I can give..
NEED to know, What Car, Stock or aftermarket system, Internal or External amp required..Dash kit or stock fit, remote or full dash radio package, Antenna in the Windshield, or none at all, or retractable, Speakers, mono, stereo, or 4,6,or 8?
Most Cars have a "Stubout" under the dash for a radio even if not factory installed with MOST of the wires you will need to get started..
Provide more, we can give you more..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-10-2006, 06:59 PM
rj57's Avatar
Most radio delelte cars still have the wiring for the radio in them.
The car or truck maker did not make a radio delete specific wiring harness for their vehicles.
So with this in mind all you have to do is locate the un-used wire to hook in to, to power up any radio you install.
Now speaker wiring, you may be at a loss here? Meaning you'll have to install these wires. (sorry)
Wiring diagram for GMC radio Gene Duncan Electrical 1 01-27-2006 06:05 PM
1986 Cutlass Supreme Radio wiring. ChrisMiddleron Electrical 3 06-21-2005 07:11 PM
radio wiring diagram help olliehighzero Electrical 2 12-24-2004 09:38 AM
Wiring a CD player up in a truck that never had a radio oldschoolrods Electrical 2 05-25-2004 10:07 PM
JVC Radio wiring Mr Bob Electrical 1 05-24-2004 04:19 AM
