Radius 23 T - rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2009, 11:40 AM
Radius 23 T - rear
Had my drive shaft shortened. The mechanic tightened the rear radius at the frame. Does anyone know the proper amount of play to allow the radius arms to pivot with the rear end/shocks?
Thanks....
Old 04-23-2009, 01:23 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Is there a bearing of some sort at the attachment point on the frame?
Old 04-23-2009, 03:32 PM
Radius
No bearings - just a bolt and a nut with flanges on both sides. My inclination is to keep the nut loose enough so that the radius rods can pivot freely up and down as the axle housing moves with the shocks. Sound about right?
Old 04-23-2009, 03:51 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
NO sorry but that just ain't right. You should have a heim joint there to pivot on. That bolt is not going to last long as a pivot, then it will break and then it gets real ugly from there.
Old 04-23-2009, 03:55 PM
Radius -
Just had a visual, and ugly is an understatement. I assume I can find the heim joints @ Speedway?
THANK YOU!!
Old 04-23-2009, 09:20 PM
aosborn's Avatar
Wiki Edits: 7
Is is possible to weld in a threaded bung onto the end of the trailing arm to allow you to install Heim joints? If you do go the Heim joint route, install greasable units and put seals on them if you want them to last any time at all on the street. Put a large OD washer on the outboard side of the Heim and under the bolt head to retain the joint if it should fail.
Is there solid structure on the frame (welded tube or something else to keep the frame from compressing when you tighten the attaching bolt on the heim).
If you are going to do it, do it right.
Andy
P.S. Post a photo of what it looks like now if you can.
Old 04-24-2009, 11:49 AM
Agreed
Still a little confused. I bought the radius ends from Speedway Motors which do not have bearings or resemble heims. I'll call their techs and find out why this set up is sold. I agree that over time, the bolts will fail and I''ll leave my rear end at a light some day. Any thoughts?
Old 04-24-2009, 05:17 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
The typical radius rod you might buy from Speedway for a T would usually be threaded on the frame attachment end for a male heim, which would be sold separately. The ones on mine are threaded 5/8 x 20, and usually all right-handed threads. The heim might also come with the locknut, but if not, you would still want a lock nut anyway so make sure you get them.
Make sure after you install them that the joint can swivel freely and the outer case shell that contains the swivel does not contact the frame or the head of the bolt going through it, which will cause a bind and quickly destroy the heim. You can use washers to do this up to an extent. As mentioned before, use an oversize washer on the outside of the heim joint in case the ball pops out of the shell.
Old 04-24-2009, 06:46 PM
Last journal entry: frame build
Sounds to me like you have clevis joints on your radius rods. They are for use with hairpins on the axle end. They don't move there and last forever. A moving joint has to have a bearing of some sort. You must already have either a threaded bung or stud on the rods for the clevis to fit on. I would just replace them with the appropriate heiom joint.
There is a special tapered washer to use with the heims to keep them togather when they do fail that also allows full movement of the joint.
1964 Impala SS Hood Adjustment 64Joker Body - Exterior 4 04-13-2008 09:11 PM
Tubbing rear with original frame rails? chieftain Suspension - Brakes - Steering 1 04-25-2007 08:02 PM
Universal 3-link kit pigman Suspension - Brakes - Steering 32 07-13-2005 03:43 PM
rear end for 23 tbucket bobby jones Transmission - Rearend 9 06-22-2002 03:37 PM
Rear Frame Kit-JEGS beetle9 Suspension - Brakes - Steering 0 04-18-2002 04:51 AM
