Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rafters need to be raised higher...
Old 04-20-2004, 01:27 AM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
That would work but add the wood BEFORE you ever cut the existing rafter. Also use 1/2" OSB for your tie plates instead of the small metal plates that the gussets are normally put together with. Add the OSB on both sides of each rafter for rigidity. Also make sure the 2x's that you install are installed symmetrically. Post some pics when done. What you are wanting to do is no different than a factory made truss.
Kevin
