Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rafters need to be raised higher...
Old 04-20-2004, 05:50 PM
60convert 60convert is offline
lift
I would say as long as you plan it for your intended use the 2 post will work to your expectations. also remeber that when the hoist is at its maximum height the car or truck on it will also be taking up all the space where the rafters use to be so make sure you make a (hole) in the rafters large enough to accomodate any of your projects.
Jesse
