rag joint interchangaable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2005, 11:54 PM
New Member
I recently purchased a 12:1 ratio steering box with a 3/4" x 30 spline input shaft. My lower half of my rag joint coupler connects directly to this input gear. My problem is that my current box has a 13/16" 36 spline. I want to know if i can take a 3/4" 30 spline lower half and bolt it to my existing upper half??? Are they the same diameter etc. with the exception of spline acceptance?? Thank you.
Old 03-15-2005, 12:17 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Yep, that stuff is all interchangeable. Jsut depends on how the engineer's wife treated him the night before whether he used splines, double-D, etc., shaft ends.
Old 11-26-2005, 08:45 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Lightbulb Added to Hotrodders Knowledge Base
This discussion has been added to the General Rodding Tech Discussions category of the Hotrodders Knowledge Base.
--For the main page of the Hotrodders Knowledge Base, click here.
--For more information on the Hotrodders Knowledge Base, click here.
--For information on becoming a Hotrodders Knowledge Base Editor, click here.
rag joint information needed 71rsz28 Suspension - Brakes - Steering 2 03-15-2005 01:50 AM
Do I need a rag joint? americanLT1 Suspension - Brakes - Steering 5 11-02-2004 12:31 PM
Steering box/Coupler (rag joint) Questions RObs71Nova Suspension - Brakes - Steering 1 10-26-2004 11:34 PM
rag joint hagood Suspension - Brakes - Steering 1 06-21-2004 08:21 AM
rag joint camaro redhead67camaro Suspension - Brakes - Steering 0 04-16-2004 09:16 PM
