rag joint replacement on '78 ford granada - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2004, 05:52 PM
Do I have to drop the steering box/rack and pinion assy. to replace the flexible coupling. this granada has a steering box and it connects on the bottom to a hydraulic cylinder--all one piece,4-bolts.It looks like the only way to separate the coupling fom the steering shaft.
thanks
Scott
Old 10-13-2004, 06:08 PM
poncho62's Avatar
Wiki Edits: 5
You should be able to get it apart enough to replace the joint. at least I could on my 78 Zepher. Of course, it has a rack and pinion.
