raise the front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2009, 08:31 AM
raise the front end
I need to raise the front end of my 66 Tbird 3". Any cost effective ideas?
Old 09-27-2009, 01:30 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
These guys can provide ANY spring on ANY car to do ANYTHING you want to do....Take the front end apart and change the springs....do it right and forget it....
http://www.eatonsprings.com/
Old 09-27-2009, 06:59 PM
Thanks alot.
Bug
Old 09-27-2009, 08:21 PM
kleen56's Avatar
I agree with Techinspector. The proper way is to remove your springs and install the new ones. I remember seeing people use an aluminum plug looking thing (pepboys sold them for under $10) You would put the edge of the plug on the spring and with a 1/2 inch rachet and extension, you would turn the plug and it would lock in between the springs, extending the springs and raising your vehicle. Only problem with that is some people ended up loosing one hitting a bump and the car would be leaning until you replaced the one that fell out. Stick with the new coil springs!
1966 Impala w/a '65 front end. Need advice. c-towndave Body - Exterior 1 01-02-2009 06:06 AM
How do I identify a GM front end? hotred86 Suspension - Brakes - Steering 2 03-25-2007 12:05 PM
1965 Impala Front End Suspension Problem EazyDuzIt102 Suspension - Brakes - Steering 2 03-29-2004 05:52 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 04:08 PM
