Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - raise the rear suspension
Old 08-16-2010, 09:37 AM
GTXKen's Avatar
GTXKen GTXKen is offline
Add a leaf spring to your current spring pack, this will raise the car and not affect the stability. Shackles look too “joe dirt”, air shocks are risky and support the car via the shock which the shock mounts were not intended to do and the other solutions like air bags get pricy.
Get a set of springs the same width as yours from a junk yard or swap meet.
Take the junk yard springs apart
Take the main spring with the eyelets and cut the eyelets off with a cut off wheel
Take the springs off your car
Replace the SECOND spring off your car with the new spring you made from the junk yard set
The only other thing you will need is a new set of center bolts which will be under $10
I’ve done this on 3 different cars now and have always had good results. It’s simple and easy, working in my little (22x20) garage I think I spent less than 4 hours total to do the last one.
Ken
