Raised Oil Temperature - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2011, 09:39 AM
malc's Avatar
Living At The Speed Of Life
I installed my motor into my 3rd gen Camaro in 2004, with oil/trans coolers.
I never had a temp gauge with the original motor so I never knew what the
going oil temp was.
Since the installation of my motor the oil temp with a 180š thermostat and cooler has always been 180š maybe a tad more in traffic.
Two months ago I had an oil cooler line failure while out on the road, after smelling burning oil I parked the car at the next safest spot.
The return oil line had been cooked by the new Hedman Hedders I installed
and I was using regular rubber line, my mistake obviously for not double checking header/line spacing.
Had the car trailered 120 miles home and installed -8 AN oil lines.
Now the oil temp runs at 210š, takes itīs time to get there but thatīs where it peaks, regardless of ambient temperature, last run was the same 120 miles at five in the morning very cool air, thunderstorm air in fact.
My questions are;
Could Anything have got damaged inside my motor when the oil line popped
causing a hot spot, it took me maybe three minutes to get safely parked ?
What is a ballpark regular oil temp number for a Chevy small block without a cooler ?
Are my oil lines big enough, should I go from a -8 to -10 ?
BTW the car runs just fine, I changed the oil and checking it shows no "sparkly stuff" in it.
Old 07-22-2011, 10:05 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi malc
I'm sure you have nothing to worry about. Even though you lost oil pressure, you shut it down within a few moments, everything would still be protected by the oil film. You oil temp is within the safe range 180*- 240* I wouldn't worry about it at all.
Rich
Old 07-22-2011, 10:06 AM
DoubleVision's Avatar
220 to 230 is the typical heat range for a stock panned small block with mineral oil. Synthetic can take some temps up to 260 to 280 but only for short periods.
Daddy Raised A Hot Rod Lover iou001 Introduce Yourself 2 08-29-2008 12:02 PM
raised exhaust ports 69er Engine 3 03-15-2005 10:31 PM
must.II raised spindles anglia48 Suspension - Brakes - Steering 2 02-02-2005 11:37 PM
Rafters need to be raised higher... Cliff Elikofer Garage - Tools 21 06-04-2004 05:48 PM
Raised White Letters? rtannert General Rodding Tech 8 01-06-2004 11:14 AM
