Raising front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2004, 03:14 PM
bct bct is offline
Raising front end
I have the opposite question that hero 07 posted. I have a 1960 mercury comet and would like to raise the front end to give it that semi gasser stance. It currently has front coil springs with the shock up the center. Ive transplanted the original 144 cubic inch 6 cyl with a 302. The rear has leaf springs so I can raise it with little problems. I'd like to raise the front about 4 inches. Any suggestions?
Old 06-06-2004, 03:17 PM
poncho62's Avatar
Wiki Edits: 5
V8 Falcon/Comet or early Mustang springs should fit. Don't know if it will raise it 4 in though.
Old 06-06-2004, 04:59 PM
aka Duke of URL
Cool
You can raise it that amount with special springs.
-EATON DETROIT SPRINGS-
Don't forget small details such as shock travel, etc.
Old 06-06-2004, 06:21 PM
bct bct is offline
Very sharp. I'm going to try changing the springs thanks for the info
Old 06-06-2004, 07:51 PM
poncho62's Avatar
Wiki Edits: 5
That picture is more than special springs............it's a whole straight axle setup.................
Old 06-06-2004, 08:50 PM
bct bct is offline
I like that straight axle, I always want a 55 Chevy with that set up. I don't think I'll go that elaborate on my comet. I think I'll try the springs and new shocks. I put spring spacers in the front just to see how it looked as well as handled but it threw my front end way off. I also have a 32 coupe and a 69 Camaro to maintain. Hopefully a 55 Chevy will be in my future. Thanks
Old 06-06-2004, 08:59 PM
aka Duke of URL
Exclamation
Don't forget, the taller springs will throw the geometry off also. You may have to make a few alterations, such as dropping the upper control arms and such. 4" is a pretty good raise.
