Raising my Rearend? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2011, 08:49 PM
Raising my Rearend?
I am installinf IFS in the front, and I have a new 12 bolt chevy rear. I do have a set of s-10 leafs which I took one leaf out, my ques is what would be the best way to raise my rear? I only want to go 2inches. I havent bought tires yet so I am thinking 14 on fronts, 15 on rear? Any suggestions, thanks, Dana
Old 07-23-2011, 09:30 PM
Cape Cod Bob's Avatar
No hurry yet to raise your rear. Figure out your tire size that you will use on the 15" rims.How it will look in the wheel well if you have 1. You can put some blocks in between your spring mounts and the frame or get some/or make some different mounting brackets. Luck
Old 07-24-2011, 09:55 AM
S10xGN's Avatar
Gotta love a turbo!
When it comes down to it, you'll prolly need to re-arch the springs or move the mounting points. I have only 2 leaves remaining from the 4-leaf springs on my S-10 and it still sets at the same static ride height...
Russ
Old 07-24-2011, 01:17 PM
I'm fine with moving my bracketry, I will have to anyway, because I am sort of starting from scratch!
New pan gasket without raising engine? rapsag Engine 14 04-21-2006 03:49 PM
Raising the Front RickB1B Suspension - Brakes - Steering 10 10-17-2004 07:06 PM
Raising front end bct Body - Exterior 6 06-06-2004 09:59 PM
Where can I find a raising kit? Fragzem Suspension - Brakes - Steering 6 11-01-2003 07:22 AM
Raising the Redline Hollywooding Engine 23 07-17-2003 11:19 AM
