Raising a seat - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2012, 07:36 AM
Leakie's Avatar
Raising a seat
What is the best way to raise a seat up 2 or 3 inches?
Thanks
Old 03-14-2012, 09:11 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Add on to the bracket that holds the seat to the floor, or fabricate new, higher brackets.
Old 03-14-2012, 09:56 AM
Leakie's Avatar
Thanks Dan
Am I making this too hard, is it as easy as adding a piece of square tubing underneath the seat brackets? No concern of the seat breaking loose from use or God forbid an accident?
Old 03-14-2012, 10:42 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Use all grade 8 bolts and nuts if you're worried about it letting go.
Old 03-14-2012, 02:54 PM
Wiki Edits: 22
Yes, you are making it too hard, and it is as easy as putting your square tubing under the seat brackets. Naturally you need to use something strong enough to support the seat, but then all you need is some 2" longer bolts than you have now.
Raising my Rearend? 39chevy Suspension - Brakes - Steering 3 07-24-2011 12:17 PM
Raising the Front RickB1B Suspension - Brakes - Steering 10 10-17-2004 06:06 PM
Raising front end bct Body - Exterior 6 06-06-2004 08:59 PM
Where can I find a raising kit? Fragzem Suspension - Brakes - Steering 6 11-01-2003 06:22 AM
Raising the Redline Hollywooding Engine 23 07-17-2003 10:19 AM
