raising torque converter lockup - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2005, 08:37 AM
i have a 700r4 in a 55 chevy truck behind a smallblock and the tranny works as it should but i would like to raise the torque converter lockup either by pressure or by speed. the result i would like to have is to have a nice wind up in 4th and then go into lockup at about 55mph. i have tried an external pressure switch and have replaced the valve in the vb but the thing still goes into 4th around 42-44mph and then into lockup around 46 mph. tv cable adjustment is not affecting it either. any thoughts would be appreciated. thanks.
Old 03-10-2005, 02:53 PM
GoneNova/406's Avatar
you can adjust the shift points with a governor kit.chevy high performance did an article on it last yr.i think in the nov. issue and super chevy did one in the april issue of this yr.check it out.i've just put one in my th-350 but don't have it fine tuned where i want it yet.its about 35.00 from b&m from jeg's for mine and i beieve yours is nearly the same thing.you can do it in a couple of hrs.including the fine tuning.
Old 03-10-2005, 05:48 PM
i was just about to try that very idea. superior puts out a governor kit that i bought a month or so back. but i dont know if changing the shift points will affect the converter lockup. i guess theres only one way to find out. thanks for your input gonenova/406, i will try it this weekend and post my findings.
Old 03-10-2005, 07:33 PM
airworld2's Avatar
change lock up
depending on the year of the 700 you change and the answer is .... this is a question I'll ask the experts........ lets see who know's there stuff I have post this answer before and have changed many lock up time with ease, triva time ohh the governer wont help with lock up
Old 03-11-2005, 07:06 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the post is difficult to understand but, airworld is correct about the governor NOT changing the lock up of the converter , only shift points.
depending on the year and valve body design you can change the mph when the converter locks up. It sounds like you may have discovered the kit the Superior offers for this modification.
If you wish to change shift points and lock up mph then you need to adress both areas inside the tranny.
It is largely trial & error since the tire size , gear ratio and normal internal pressure leaks will affect the shifts points .
Old 03-12-2005, 08:41 AM
I am reluctant to spec a manufacturer, but B&M has a kit that uses the speedo drive to vary the lockup points thru an adjustable switch in the drivers compartment. Works great but does require some wiring to install.
Lockup can also be controlled by the valve body pressure switches, but this will require some trans expertise... how adventurous are you?
Crosley is right about the variables he lists.
Lockup in a 700 is controlled (in the end) by the activation of the solenoid in the pump. Controlling the current path to the solenoid is the easiest way to control lockup activation.
Old 03-12-2005, 05:47 PM
airworld2's Avatar
lock up
you can change lock up in ways I would like to address in more detail
pressure switch is the easy way, besides a toggle switch
you can replace the spring(stronger) in the tcc valve in v/b ahhhh
and for the late style replace the solid sleeve with early valve assemble and drill the plate so oil can stroke the valve install ck ball in lock up solenoid and no power is needed for lock up in the application
this way the only cost you have is time and a spring, I have try ed all ways and depends on what your willing to try....
some times to fix problems its takes will and determination
Old 03-12-2005, 08:56 PM
This works great only if you have the correct valve, shift sleeve and spring. I bet there are thousands of these laying around for the average guy to get his hands on.
Besides, are you gonna post the correct plate drilling instructions online AND take responsibility for this info?
We need to deal in reality here.
Old 03-13-2005, 11:21 AM
airworld2's Avatar
lock up
yep I can back up what I post
as for the valve there are still many valve body around that contain the parts you need. I can even ship the parts we have a hard parts and core supply business with in the family business three Transmission shops in the Houston area. I can assure you results based on my knowledge and experience providing the tranny and converter are in GOOD working order
easy to hard I tried many things some work some don't>> this works
lets not do the my dog is bigger than your's on this.
Old 03-13-2005, 07:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
chazmac...... airworld knows of what he speaks.
he has the knowledge and experience.
the 3 of us know the method airworld speaks of will work with the correct valve body , parts and modifications.
I am of the opinion the B&M adjustable lockup kit is easier and faster to change the lock up mph .
Old 06-10-2005, 08:21 PM
Roadsire's Avatar
Last journal entry: Dash mods
Good 700r4, 4l60 web site
Here is a great web site for 700r4-4l60e tranny info.
http://www.purplesagetradingpost.com...o/700R4p1.html
I hope it helps........
Old 06-10-2005, 09:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I provided a large part of the information at that site
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 06:23 PM
How much torque can a turbo350C (lockup converter) take? supercab78 Transmission - Rearend 3 02-28-2005 06:00 PM
Is my jeg's brand torque converter a dud? elukas Transmission - Rearend 5 10-07-2004 11:08 AM
C5 or Torque Converter Bad? k2mooch Transmission - Rearend 2 11-30-2003 08:27 PM
What Can I Really Expect From a High Stall Torque Converter ? white66coupe Transmission - Rearend 3 05-25-2003 05:21 AM
