-   -   Rally stripes? (http://www.hotrodders.com/forum/rally-stripes-77770.html)
bodyworksbysteve 01-02-2006 09:54 PM
Rally stripes?
Planning a complete paint job with rally stripes next week in base clear, never done this before so I could use your tips! The car will be blue with two white stripes down the hood, roof, and decklid. I'm thinking to do the white first, its the lightest color and less masking off of my first color. right? I have blue fine line tape is there something better for straight lines that won't peel up my first color? Any shortcuts to laying out my stripes, I plan to measure out from the center, but is sounds like work to get them lined up straight. And then I plan to cut and polish, will I run into problems around my tape lines? Thanks in advance for any help- Steve
302 Z28 01-02-2006 09:57 PM
Normal process is spray the car your base color then apply the stripes over the base color, that is how the factory did it.
Vince
MARTINSR 01-02-2006 11:55 PM
What kind of car is this? If you are planning stock "Rally stripes" on say, a late sixties Camaro or Chevelle, and I assume Mustangs and such, they all have stencil kits that make it a BREEZE to spray them.
I sprayed many of those stripes masking them off with a ruler and my eye. After the first time I used a stencil kit, I was hooked. Never will I go back to free hand.
Paint the car first and then using the stencil kit you are done in only an hour or so, it is that easy.
bodyworksbysteve 01-03-2006 08:24 AM
This is a 66 mustang fastback the customer wants a Cobra look. I'll check for a cobra stencil kit. Thanks
What about colorsanding over my stripe tapelines will I run into problems?
And does everyone agree to mask off the whole car to do the stripes last?
-Steve
MARTINSR 01-03-2006 09:19 AM
Yep
