Ram Air Boxes - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-28-2008, 03:44 PM
I made a ram air kit myself. It was very roughly done, but if you put a little more time in it you can get it quite nice.
I bought found two used snorkels. I think the 77' Caprice was equipped with a snorkel, and probably loads of other GM vehicles.
The tools I used
Sheet metal I found at the local metal dump
Here I've cut off the old airfilter box inlet. The best tip would be to find a box that was designed for a snorkel originally, and then attach the inlet of a second box.
Made a new inlet of the sheet metal, and pop nailed it to the box. I filled the gaps with sicaflex.
Both inlets in place. The right one is longer due to some rough measurements.
Before paint
After paint. The left snorkel is in the factory position (fan shroud has bolt points for the snorkel).
Another shot after engine clean up and upgrade.
Looking for a ram air cleaner xxllmm4 Engine 6 12-22-2006 05:05 PM
Ram Air Hood Performance rfowler Engine 5 12-08-2006 10:02 AM
respirators and supplied air robs ss Body - Exterior 12 08-30-2006 07:44 PM
ram air or cowl hood for the horses? iroclife Engine 8 04-01-2005 07:19 PM
RAM Air in a 68 Goat nomis30 Engine 0 08-25-2003 02:33 AM
