ram jet 454 zl1 #105 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2009, 01:41 PM
low oil pressure 10 pounds checked oil pump all plugs are tight going to try 50 wt oil only ran it for about a minute to scared to warm up though please someone help
Old 10-06-2009, 04:02 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Is the 10 lbs. at idle? When you say "checked oil pump", what did you do to check it?
Could be a defective gauge or air in the line.
Could be a bad oil filter. Do you have a Fram filter on it? If so, replace it with a Wix or Puralator. Make sure you fill the oil filter before installing it.
Old 10-06-2009, 04:07 PM
OLNOLAN's Avatar
Noisy ?
Hey 23, Is it making noise? (are the lifters tapping?)(is the engine knocking?) If it's not making noise, you could just have a mismatched oil pressure sending unit/ gauge. Or a partial blockage in the sending unit, it happens occasionally on new engines. Let us know.olnolan
Old 10-08-2009, 01:17 PM
yes the 10# is at idle i put a snap on oil pressure gauage on it there is no unusual noise i put a remote oil filter stanless screen but also tried with paper filter same pressure . on checking pump just visually checked for un even wear on gears gettin a hvhp pump i do get 35 40 pounds at 3grand
thanks any other ideas whats normal idle pressure
Old 10-08-2009, 02:14 PM
oilpresure
that's what ya get for buying a GM Cratemotor.... just kidding... i saw on a hotrodding show that low oil pressure on a GM crate is ' normal'.
what?
Lifting a Ram Jet 502 powerplay13 Engine 1 08-09-2009 07:30 PM
GMPP 350 Ram Jet 36fd Engine 1 09-03-2007 07:20 PM
Ram Jet, Ramport, or StealthRam EFI? Blownolds Engine 0 12-16-2003 09:47 PM
ram jet 350 toadman Engine 4 04-27-2003 08:58 AM
ram jet 350 engines mike bryan Engine 4 01-23-2003 05:37 AM
