Ram Jet 502 Coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2013, 09:21 AM
Ram Jet 502 Coil
Hi,
I was hoping someone can help me.
I'm building a 26 Cadillac with a 502 Ram Jet.
I'm wiring the car now, and need to mount the coil but don't know where to put it. I'm assuming it has to go on the firewall (right side just above the head?), but I don't think it will look too good there. Can the coil mount on the inside of the firewall in the car?
Also what is the max length from the coil to the distributor.
Thanks so much!
Old 08-18-2013, 09:50 AM
vinniekq2's Avatar
make sure the coil is pointed up( most coils) inside is fine. be reasonable about coil wire length
Old 08-18-2013, 10:10 AM
Thanks!
Why does the coil need to point up?
Old 08-18-2013, 10:47 AM
vinniekq2's Avatar
some coils have oil in the bottom. Some people blame coil failures on the coil being mounted upsidedown or other positions other than straight up.
Ive only had one coil failure that I can remember,a long time ago.
read the mounting instructions if using a quality after market coil.a lot of factory low performance coils are mounted close to horizontal
Old 08-19-2013, 10:44 AM
The Ramjet coil
1115491-Ramjet 502 $62
1115498-Ramjet 350-$68
Mount it anywhere you wish, t I think these are dry coils as they have a decent heatsink on them. Same coil as the Vortec truck, LT4 engines used with different connectors bracketry.
peace
Hog.
Old 08-21-2013, 04:44 PM
Thanks all...........
Now, where do I find longer coil wires?
Old 08-21-2013, 06:42 PM
Banned
why not hide it, clean motor bay with a $10k motor! Make the coil wire !! also post some pictures of this!!!!!
Old 08-21-2013, 07:18 PM
I tucked it behind the new firewall low near the frame............
I'll take some pics and post tomorrow.
Old 08-21-2013, 10:41 PM
vinniekq2's Avatar
any wire in a set can be a coil wire,,,, you can buy one wire at a time,,,and you can buy a spool of wire,,,and you can buy one piece off a spool of wire
Ram Jet 502 OIL leak Head? karfever Engine 6 04-03-2012 10:30 AM
Lifting a Ram Jet 502 powerplay13 Engine 1 08-09-2009 06:30 PM
502 Ram Jet 2FNFAST Engine 7 09-27-2007 05:57 AM
2-stroke Ram Jet 502? JollyBFD Engine 15 11-18-2005 10:41 PM
502 RAM JET CHEVY CRATE ENGINE del ammons Engine 1 01-29-2003 11:52 AM
