Based on this photo (
http://www.britishv8.org/Articles/Al...ve-Engines.htm) it just might fit. The intake plenum is high on the engine, so it would be above the narrow point in the engine bay. Transmission adapters/bells are high at $474 though (
www.quad4rods.com). I think the bolt pattern is the same as other GM fours and small V-6s though, so you should be able to use a Camaro trans or Jeep 2WD trans (the Jeep 2.5L used the same pattern as Chevy fours and small V-6s). Not positive on the bell pattern though, might be unique to the Q4.
