Rambler American engine conversion #2 - Page 10 - Hot Rod Forum : Hotrodders Bulletin Board
  #136 (permalink)
Old 05-16-2010, 01:44 AM
ramzoom's Avatar
Interior got started Friday..Heres a shot of the carpet going in..It looks gray but it is actually a lt. green color..sounds weird but so far looks nice and clean...
The rest should be completed Monday
  #137 (permalink)
Old 05-16-2010, 09:39 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
I bet some of the magazines pick up on this car at the shows this summer because of the seemingly unusual engine/car combo.
  #138 (permalink)
Old 05-17-2010, 06:31 PM
ramzoom's Avatar
Well, the back seat is in and the rear door panels were pulled and re-dyed. There was some fading and discolor from age and use. They turned out nice. I didnt want to do new panels and the originals were in pretty good shape. Should have more done tomorrow
  #139 (permalink)
Old 05-19-2010, 10:15 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
very nice. Its good to see the progress.
  #140 (permalink)
Old 05-21-2010, 10:38 PM
ramzoom's Avatar
More interior progress......
  #141 (permalink)
Old 05-22-2010, 09:25 AM
farna's Avatar
Wiki Edits: 14
Can't wait for a drive report! Too bad I'm all the way on the other coast... I might be trying to talk you into a test drive! Tom Jennings and I are two of the few who've taken that body and really wrung it out before, and that with only slightly warmed up 196s (can't do much more to that motor)! With a modern engine in it.... gives me goose bumps! I always wished I had a quicker revving engine in mine. At least the old 196 never did lack low speed torque.
  #142 (permalink)
Old 06-06-2010, 11:02 PM
ramzoom's Avatar
Well...I have a computer problem so I am posting from the blackberry..I lost spark on the Q4 and it turned out to be the ICM module. The unit from Q4 rods was used and upon removing the coil packs we could see it was crusty and in pretty poor shape..so I picked up a new ICM and the little Q4 fired right up. We let it idle (with occasional rev) for at least 30 minutes and it ran so much better then before. The top end quieted down as it broke in and the temp hung between 170-180 degrees at idle. We did however remove the intake and blower to install fuel injectors and a rail system to lock them in place. We will reinstall the intake Monday and refire the car. The injectors just plug the holes..I wasn't happy with the original method..
I should have a lot of progress this week as we plan to push hard..
I do have a video taken with my phone..I will see if I can get it loaded? Again pc is down..phone audio may stink too? Lol..
  #143 (permalink)
Old 09-04-2010, 05:56 PM
ramzoom's Avatar
Well, the Rambler is running and driving. Had a few problems but we work them out as we go....The coil packs and ICM gave issues..the ones you get from Q4 rods are used. A new ICM solved a no start issue...Took the car home and it was running but I felt something was off and it didnt seem to have the power I expected..Took it to a show last Sat and it was a hit..of course when I went to leave the darn thing ran rough! I thought I sucked some junk into the carb but we dropped the tank and cleaned it and installed a fram filter as well as another filter at the carb...ended up being one of the coil packs! So I swapped the pack out and it runs really good now. I plan to throw some MSD packs in soon. Went for a test drive and it runs great. Lots of reving...I threw some 4:11's in which helped alot! It pulls through all the gears. I plan to change the exhaust and run it out the back with a different muffler..kinda loud right now...Shifts smooth...Its over 100 degrees here in So. Cal nd the little car runs around 200 degrees. I'll get some pics up soon..
  #144 (permalink)
Old 09-13-2010, 09:31 PM
ramzoom's Avatar
A short drive video....
  #145 (permalink)
Old 09-13-2010, 10:41 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Sounds really good.
  #146 (permalink)
Old 10-13-2010, 10:40 PM
ramzoom's Avatar
For Brian.................
  #147 (permalink)
Old 10-13-2010, 10:45 PM
Thank you SO MUCH for posting that photo so fast. I just can't believe what I am seeing! What in the living hell would be the reason for that gap? I am THRILLED to hear I don't have more work to do on this car but that is so darn strange I just can't get over it! My car looks stone original and there is no sign of any sealer of any kind there! I need to pull the carpet up on my parts car I know it's virgin to see what is there.
  #148 (permalink)
Old 10-13-2010, 10:56 PM
My "crack" does have what looks like a couple small half inch welds at the top that has broken. And the parts car did as well as I remember from looking up from under the car. Did yours look like it once was welded right at the top? I just can't get over this thing, what in the living hell would be the reason for it?
  #149 (permalink)
Old 10-13-2010, 10:58 PM
Your video is awesome by the way! I plan on shooting a video of the first time I pull out of my driveway.
  #150 (permalink)
Old 10-14-2010, 12:39 AM
ramzoom's Avatar
Cool...I dont recall any welds?? I will have to see if my Rambler wagon has the same thing and how it looks..I remember a piece of rubber across there..that sticks in my mind..
I will check tomorrow...
I havent driven the green coupe in a couple weeks..I want to change the accelerator pump jets..
Catch you later.....
Rambler American help 78 elky Engine 14 06-17-2010 10:27 AM
chassis swap on a '60 Rambler American SW Roger W. Taylor Introduce Yourself 6 10-04-2009 08:14 AM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
'68 Rambler American parts jlhart Introduce Yourself 1 06-08-2006 12:56 PM
Cadillac Engine for a rambler? Farthingfan Hotrodding Basics 10 09-17-2005 09:44 PM
