Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rambler nose to the ground
Old 12-16-2009, 07:13 AM
matt167 matt167 is offline
Wiki Edits: 31
really the cheapest and easiest way to fix it would be to rebuild what you have. the suspension is really simple, and the parts are available to rebuild it.. it sounds like the trunions collapsed which can happen if there never serviced ( greased ). there available new on Ebay or www.kennedyamerican.com or www.ramblerparts.com have rebuilds and you just send your old 1's back.. both of them will have new springs also.
