Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rambler with nova subframe
  #27 (permalink)
Old 12-09-2009, 06:24 PM
CQNRQY CQNRQY is offline
CQNRQY
simple cheap and compact
Maybe consider a mustang/pinto/bobcat front suspension.
They come cheap, parts are easy to get oem and at the speed shops.
rotors with different wheel paterns are available. They're easy to widen or make narrower. I'm considering this for my 53 willys if I can't find all the parts I need for it. I'm trying to keep the original drive train in it .Rod it like it would have been done in the early 60's. Split manifolds 2carbs finned coil etc.
Just like belly buttons, everyone has an opinion.
It's all good, I heard it said once on this forum, I don't know if I can believe it or not, but from what I understand "It's your car, do as you want".
You need to measure that track again though, I just did mine and the track (center to center of the wheels) was about 54 inches.
Hey, get some clip under it and see if it work for you.
