Ramp sliding. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2010, 09:39 PM
Rooster13's Avatar
Ramp sliding.
Has any one come up with a simple solution to stop those damn drive up ramps from sliding on a garage floor.
Old 12-13-2010, 10:18 PM
Semper Gumby
Wiki Edits: 2
Ramp sliding
Just weld/bolt a "tongue" onto the front so that the car wheel sits on the flat "tongue" and holds the whole works in place as it climbs the ramp itself
Old 12-13-2010, 10:21 PM
I fought that problem for decades.
Finally solved it by cutting a 3 ft long 2x8 to fit between the ramp
edges, and drilling 2 holes to bolt the board onto the ramp end.
This basically extended the ramp and gave a smaller drive-up angle.
Works great.
Old 12-13-2010, 10:53 PM
Wiki Edits: 27
drill holes
I just grab my Bosch Bulldog concrete drill and poke a couple holes in the floor, I have welded a piece of angle iron across the front and bolts sticking down to pin into the concrete, I put on the safety face mask and blow out the dirt every so often.
Old 12-14-2010, 08:14 AM
Rooster13's Avatar
Ramp sliding
Thanks for all the feed back. I am sure now that I will solve the problem thanks to all your simple logical solutions. Usually I amaze myself some times with a problem solving solution that I pull out of some where ( usually my A**) but on this one I missed the Short Bus.
Tilter; Rotisserie; or Ramp? ndustrl Garage - Tools 40 01-27-2010 09:44 PM
Sliding ragtop or panoramic Sunroof? 427v8 Body - Exterior 3 04-10-2007 11:12 PM
Removing ramp on swirl port head McDeuce Engine 8 09-13-2006 08:15 AM
Redneck work ramp Wmarden Garage - Tools 7 10-10-2004 10:37 PM
Converting G-20 Sliding Door to #2 Hinged? Stick'n It Body - Exterior 0 07-12-2004 12:56 PM
