rams horns - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2008, 09:28 PM
Cape Cod Bob's Avatar
rams horns
I have late 60's and want to find out where or who makes the flange and exhaust pipe. I will be welding up my own pipes but napa wants $85 just for a set of flanges and a short pipe that is crimped to fit the exhaust header, No donut.
Anyone know?
Old 07-02-2008, 09:48 PM
Not sure what you're asking about a ram's horns set of flanges. You have ram horn manifolds no? Meethinks you just need about $10 worth of crap for that. I'll look at a set of those hangin on the wall in the a.m.
Old 07-02-2008, 09:51 PM
SSedan64's Avatar
A friend of mine had a muffler shop bend a pair of those for $25 total.
Old 07-03-2008, 03:13 PM
Yes. I have rams horns and want to get to exhaust pipe . Need the three hole flange ,donut and some pipe to get started.
Napa does not carry this item even for the OEM.
However they can get me a stub pipe that is crimped like a donut and fits into the manifold and supply a flange . But cripes $84 bucks sound rediculuse!
Old 07-03-2008, 03:18 PM
302 Z28's Avatar
Most any muffler shop worth their salt should be able to fix you up for a lot less than $85 I would think.
Vince
Old 07-03-2008, 04:04 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
The swagged collector and donut at a muffler shop should be about $25 for both sides, including a foot of pipe.
Old 07-18-2008, 05:44 PM
alittle1, u were right. 2 donuts,2flanges and 2 flared stubs $29 at a good midas and a good exhaust man. Took longer to price it then it took to make 'cause they don.t usually do little jobs like that.
Old 07-19-2008, 08:17 AM
How close is the angle of the Rams Horn pipe outlet to the angle of the original exhaust manifold? I would like to put a set of 2 1/2" Rams Horns on my '75 pickup (SBC 350) , but I'm not sure how difficult it will be to route the down pipes.
In general, I have quite a bit of room in the engine compartment, but I have to work around all the 4WD components (axle, and transfer case mounts) when I route the pipes.
Thanks,
Bruce
Old 07-20-2008, 05:19 AM
I am not sure of the angle.. They do not drop straight down .They turn about 45 deg.
Old 07-20-2008, 05:57 AM
SSedan64's Avatar
On 4X4 Blazers & Pickup up to 72 the left/driver side goes straight down and the right/pass side is at @45* angle. Not sure if 75 would be different. Bolt pattern at front may be different like here. http://www.chevytech.com/3c10o9.html
Here's a few manifolds>.
http://search.stores.ebay.com/Car-Parts-Wholesale_blazer_W0QQfciZQ2d1QQfclZ3QQfsnZCarQ20Pa rtsQ20WholesaleQQfsooZ1QQfsopZ1QQfsubZ5880524QQsas elZ139020616QQsofpZ0[/url]
Old 07-20-2008, 06:30 PM
The engine in my truck is a GMPP 350 that is about five years old, and I think the bolt pattern will work fine with either type of manifold. I have to take a look at the angle my current manifolds and see if they are similar to the angles on the Rams Horn. The manifolds I found in the parts catalog are for a Corvette with 2 1/2" exhaust, not the more common 2" Rams Horns that were used on GM trucks and small block cars.
I think they will fit, but getting header pipes bent by a muffler shop is hard to do if I have to have the manifolds mounted on the engine first. Once they are mounted (at home), I have no exhaust until I get to the shop. The cops may not really like the sound of a 350 with no exhaust.
Thanks,
Bruce
Old 07-20-2008, 07:27 PM
Thanks,
Bruce
i do
Old 07-21-2008, 10:32 PM
If you have some mufflers or maybe a couple of 2.5"x90* mandrel bends in the back, they might actually believe you're heading for a muffler shop. The first time, anyway.
Old 07-23-2008, 03:09 PM
45 degree rams horn availablility
I have the same 45 degree 2" rams horns fitted to my 49 F-1 with a 350. I am going to have to go down the same path but I want it in stainless. I can't use the straight dump rams horns due to a clearance problem with the pinion shaft into the jag rack. I am set up with a Jag XJ IFS. Does anyone know if the 45 degree rams horns were other than the 2" ones that I have? (i.e.
2 1/2"?)
Old 07-23-2008, 06:06 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Corvette's use 2 1/2" up until 1982 if your still looking for a larger set.
Most roundy round guys use them for the flow.
Luv the smell of NITRO in the morning.
How do I wire up my horns? cpthowdy Electrical 6 07-13-2008 10:11 PM
sb chevy rams horn exhaust manifolds NorthStar Engine 11 07-25-2005 10:50 PM
Headers-replacing rams horn manifolds 65vettestroker Engine 3 11-06-2004 07:39 AM
What size cam w/ Rams Horn Manifolds on 383? laitch Engine 2 02-09-2003 02:40 PM
Best for Torque: Rams Horn or Headers??Help today! 6/14. bullheimer Engine 9 06-17-2002 11:34 AM
