Random HP guesses please - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2009, 10:00 PM
454headache's Avatar
It's late, I'm bored and am away at work not able to play with any of the toys so...
I'm curious to see how much hp my mild engine makes and what 1/4 time it would run. Yes, I know its a very heavy vehicle and a mild engine, but for what its worth, every time I stomp on the gas pedal from a stop, the thing will light up both tires and keep them spinning until 40 mph. Here's the truck-
'90 C1500 2WD Lowered
4500lbs estimated
TH400
12 Bolt rear posi 3.73 gears
Regular bland street tires (275 wide)
Engine-
454 fresh rebuild
Roller Cam .483 lift, .224 duration @ .050, 115 lobe center (GM #12551622)
9:1 compression
Intake Port Flows
CFM @ Lift
63 .100
121 .200
165 .300
198 .400
226 .500
242 .600
Exhaust port = 81.2cc
Intake ports = 233.2cc
Dual Edelbrock Carbs (progressive linked)
Dualplane intake
Long tube headers (forget what tube size)
No cats, fairly open mufflers
Old 09-09-2009, 11:30 PM
ericnova72's Avatar
More for Less Racer
If it would run 14.5 seconds in the 1/4 mile I would be flat out amazed. You might be making 420 hp at best, 500 ft lbs torque.
Old 09-14-2009, 09:53 AM
those are small intake ports. what heads are those?
400hp/500ftlbs is my estimate if the port flow is correct.
Old 09-14-2009, 12:11 PM
They are Vortec L29 iron heads. Large peanut ports if you will.
Old 09-14-2009, 03:25 PM
The engine is the L29 not the heads.
the 7.4 vortec heads are 12560241.
the flow numbers you are using look like L29 small block head numbers.
Old 09-14-2009, 04:41 PM
I believe 4500 is a bit on the high side for a 2wd, I think that is about the weight of my 93 4x4,but then again its a small block.
Shane
Old 09-15-2009, 10:44 AM
I'm going to guess 1 hp Bob!
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
eagle crank hp rating. engineman302 Engine 4 04-10-2005 04:38 PM
260 HP or 290 HP GM Crate motor Iceberg Engine 4 02-26-2005 01:26 PM
A few changes to 540 hp carcraft buildup... what kind of hp loss? guesstimates please elukas Engine 16 08-07-2003 07:54 PM
didn't know where to ask this but HP and TQ relationship? stonedchihuahua Hotrodders' Lounge 11 12-14-2002 03:02 PM
