-   -   Ranger Brake Lights (http://www.hotrodders.com/forum/ranger-brake-lights-46837.html)
nova69 09-01-2004 12:36 PM
Ranger Brake Lights
The mechanical switch that actuates the brake lights on my 93 Ford Ranger doesn't work until the brake pedal is pushed down almost to a lockup position. I've tried a new switch, and I even tried to shim it to get the thing to work at a light pedal. Needless to say, in traffic where a light pedal is often all you need to slow, the driver behind needs to know you are on the brakes. That isn't happening. Any suggestions? Thanks.
docvette 09-01-2004 04:05 PM
Switch
1 Attachment(s)
Doc here :pimp:
Does that have a Finger to activate the switch? If so bend it forward.
Is this the switch?
Doc:pimp:
nova69 09-01-2004 11:50 PM
Thanks, Doc. That appears to be the switch, but I don't recall a "finger" on the unit. I'll look closer and post my finding.
