ranger posi trac - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2011, 04:00 PM
ranger posi trac
can anyone tell me if any ford rangers came with posi trac rearends and if so how to identify one
Old 05-31-2011, 06:50 PM
Wiki Edits: 31
Plenty did, but not many 7.5" rears, so a 4cyl truck is pretty much out.. You can go by the axle code, or the axle tag.. F ( 7.5" ) or R ( 8.8" ) are the LS axle codes for Ranger.. If you go by the tag, it is usually held on by a cover bolt, and if you clean it up, you will find all the info about that axle including the ratio.. An L/S rear will have an L in the ratio, so it will say like 3 L 73 or 4 L10
If you are axle swapping, then you might look into Explorer Axles. There a little wider, but swap in pretty easy, and easier if you want to lower, because they eliminate the need for a flip kit ( axle over leaf, like the explorer ).. They are 31 Spline, limited slip is easier to find and 1995-2001 are disc brake
http://www.therangerstation.com/tech_library/Axles.html
Old 05-31-2011, 08:07 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
^^^^there is a ton of info at therangerstation^^^^
Old 05-31-2011, 11:20 PM
Wiki Edits: 27
mustang GT parts.
I ve read that Mustang gt LS parts also work . Ive put rear ends together in the wrecking yards, mustang 4 bolt starting point. used ranger 5 bolt axles and lincoln 5 bolt rear disc brakes
How Do I Tell If Its Posi Trac chevy bb 572 Transmission - Rearend 17 04-06-2009 11:38 PM
need info on gettin a new posi trac zak Transmission - Rearend 6 10-07-2008 12:31 PM
Posi-trac 10 Bolt Meangreen Transmission - Rearend 1 07-12-2003 03:00 PM
Posi-trac Experts (If it ain't broke, should I fix it?) Axelrod Transmission - Rearend 3 05-21-2003 06:23 PM
posi trac and gas mileage 67-camaro-69 Transmission - Rearend 1 11-17-2002 07:20 PM
