Ranger V8 conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2012, 05:31 AM
ok. i have read and read about the ranger V8 conversions. unless i have overlooked some i have not seen my answer. i have a 94 Ford Ranger 4.0 and i have a junk 94 F-150 with fuel injected 302. i want to put the fuel injected 302 in the ranger. the question is it even possible? should i use the 5 speed manual or find a automatic tranny for it? and where can i get headers for the conversion.
Old 08-23-2012, 08:08 AM
Wiki Edits: 31
It's pretty easy actually. To get the motor in there, you need 5.0L mounts for a Fox body convertible Mustang. It will take some cutting and drilling but they fit right in. Wiring, you'll need the EVTM for your truck and the F-150. There both EEC-IV so it should be pretty straight forward. You'll need to go thru the wiring and splice the F-150 engine wiring harness to the Rangers main plug ( big round plug ).. As for the transmission, you can't use the trucks 5spd, as it puts the shifter way too close to the Ranger dash.. Mustang T5 is a popular swap but that puts the shifter between the seats, an S10 tailshaft can be used to put the shifter in the stock location but it takes some modding and time. Auto would be far easier. Headders are easy/ pretty cheap. Early mustang Tri Y's fit almost perfect. I think Headman quit making the Ranger swap headers but they were garbage anyway.
Old 08-23-2012, 08:30 AM
Thanks. Wow it sounds easy cause I have the whole F-150 so harness computer everything is there. I really want to keep the 5 spd. Is there anyway to modify the ranger tranny to mount to the V8.
Old 08-23-2012, 08:31 AM
Wiki Edits: 27
ranger swap
I put a 302 - C4 into my 83, I ordered the info pack from one of the companies that sell kits. My 96 Mazda looks like the same chassis as the 83, the 4 banger is still running. If it dies it will get a 5.0 ..I used Maverick V8 motor mounts and stock Maverick exhaust ,fabbed my own mount brackets, had to heat the Ac heater box and push with a leather glove to get valve cover clearance. I raised the body 2 in to get more clearance, they say you don't have to. A 460 Ford van oil filter casting that tilts the filter will work on mine, or you use the remote filter and run the rubber hoses. I think for my drive shaft I used stock pieces from Mustang 5.0 and ranger and didn't have to cut it.. You can probably get more info on the Ranger Station Forums.
The Following User Says Thank You to timothale For This Useful Post:
rangerman (08-24-2012)
Old 08-23-2012, 08:35 AM
Thanks. I want this to go as easy as possable. So any info and tricks and lessons learned will help me.
Old 08-23-2012, 08:43 AM
Wiki Edits: 27
Trans Mod
Years ago we put a pinto 4 and 4 speed into a Nash Metro, I took the trans apart and used a sawsall and sliced the tail housing casting to seperate the part that has the shifter then moved it foreward and Tig welded the aluminum shifter piece as far foreward as possible on the tail casting then shortened the shifter shaft. With all the oil in the casting it bubbled a lot when welding so we smeared a lot of rtv over everything, It didn't leak but we didn.t want to have to pull it apart. 82-3 5.0 mustangs ran the RUG or SROD overdrive trans but the shifter was to the back. I Think Ford vans used a SROD 4 speed that had the shifter farther foreward, That trans is aluminum overdrive , a modified design of the Famous old Ford Top loader 4 speed, a stout trans.
Old 08-23-2012, 09:05 AM
Wiki Edits: 31
They use integral bellhousings so, not without a custom adapter.
Old 08-23-2012, 04:02 PM
Ok well thanks for the info
Old 08-23-2012, 04:23 PM
1pickup's Avatar
Flathead Freak
ranger
I had an '83 w/ a small block Chev & 4 speed. Used the stock clutch master/slave. Had to either modify the trans tunnel, or put in a small body lift- that's what mine had. That thing surprised many of "hot rodders."
Old 08-23-2012, 09:04 PM
Cape Cod Bob's Avatar
Ford Ranger Bronco II V8 conversions kits, transmission adapter, motor mounts, aluminum radiator, oil pan, billet cap, A/C pump
Ford Ranger Forum - Forums for Ford Ranger enthusiasts!
Old 08-24-2012, 07:34 AM
Wiki Edits: 31
The kits are a total waste. some of the Motor mounts from the kits are nothing more than vert mounts, but vert mounts are usually less than $10 each, and being a Mustang mount, poly mounts are also available..
4.0L Radiator is also the preferred radiator in a 5.0L swap which he has being his truck is a 4.0L
302 conversion, ford, ranger
ranger v8 conversion xkeithxwaynex Introduce Yourself 3 09-14-2009 06:10 PM
Ford Ranger V8 Conversion nightrain_rod Hotrodders' Lounge 53 07-15-2009 11:45 AM
Conversion Ford Ranger V-6 to a V-8 Ford Wagon Engine 5 03-08-2008 12:50 PM
Ford Ranger V8 Conversion izzymiddleton Hotrodders' Lounge 13 11-15-2005 12:23 AM
ranger v-8 conversion alegath Hotrodders' Lounge 3 02-12-2004 07:36 PM
