Start a wiki article on any hotrodding subject:
Then, others help to build it.
Read and write hotrodding articles in the Crankshaft Coalition Wiki.
See 150+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 09-19-2007, 10:11 AM
ranrodder ranrodder is offline
ranrodder
Have a 2001 chevy S-10 blazer 4.3 V-6. fuel injected When you first start the motor it idles fine and high rpm is ok. As the motor warms up the idle gets rough but high rpm is ok. Seems like it is running rich. It just started this about 2 wks ago. Can someone tell me what to look for to correct the problem. Thanks ranrodder
Old 09-20-2007, 03:53 PM
bigjames406 bigjames406 is offline
Check You Iac (idle Air Contol Valve) It May Need To Be Cleaned Or Replaced. Or You May Have A Vacuum Leak.
Old 09-20-2007, 04:43 PM
HalfOunce HalfOunce is offline
I would start with checking it for codes..If you do not have a scanner, most part stores will have one they can check it with. Once you have the codes post back to this thread with them if there is any.
Old 09-20-2007, 08:30 PM
Chevrolet4x4s Chevrolet4x4s is offline
Chevrolet4x4s's barnstarLast wiki edit: How to title a hot rod
Welcome to Hotrodders Goodluck with the blazer
Shane
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
