Rant about aftermarket sheetmetal - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2010, 08:43 AM
cyclopsblown34's Avatar
Colorsanding painter
I'm currently working on a 69 Camaro and it has all new sheetmetal for the frontend. It is supposedly from a top aftermarket manufacturer but holy cow its it ever crap. The driver side fender is 1/4" longer than the passenger fender down the top and the side. Where the driver fender butts up to the header panel, it is curved away from it. It doesn't match the curvature of the door and the door is an unmolested original. Is this common with aftermarket sheetmetal? I've never had this much trouble with later model aftermarket sheetmetal.
When the car was dropped off at my house/shop, all the metal was haphazardly installed on it and it was obvious it didn't fit at that point. I knew I had some cutting and welding to do.
Thanks for reading and sorry for the rant, I just needed to vent.
Old 01-18-2010, 09:09 AM
First off ANY aftermarket part is going to be garbage simply by the odds. As a friend of mine said once after opening a box that just arrived with a part for his 65 Vette.
"If they wanted to be honest, instead of saying Exactly as original in the catalog they should say Similar to original, can be used if nothing else is available"
I have taken "good" repro parts off of a finished, painted car to replace them with damaged original pieces I then repaired. Repro sheetmetal is usually GARBAGE and I will avoid it at all costs. I MUCH, MUCH rather repair old rusty metal than spend MORE time putting some Chinese piece of crap on the car.
So no, you are not in the minority.
Old 01-18-2010, 09:23 AM
It wasn't even CAPA/Cert Labeled. It just had a part number and made in Taiwan on it. I found out last night the owner has the original fenders at his house but they're dented. I'm going to see if he'll go for me fixing and using them and then he can sell this aftermarket crap.
Thanks Brian, your posts and BDBM's posts make sense to me and get me in the right direction.
Old 01-18-2010, 10:01 AM
50 year old worn out production dies that GM sold for scrap 49 years ago.
Bogie
Old 01-18-2010, 10:17 AM
poncho62's Avatar
Wiki Edits: 5
Bogie
Only, 40 years old....but the point is still the same.......
Old 01-18-2010, 11:22 AM
Bogie
I believe this has proven to be an urban myth. They were destroyed before being scrapped.
Old 01-18-2010, 12:30 PM
poncho62's Avatar
Wiki Edits: 5
Thats probably why they make such crappy parts with them.........
Old 01-18-2010, 12:32 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Now one understands about getting involved with the guys at metalmeet.com and learning how to make sheet metal parts from sheet as at the end of the day your parts will fit better than what we get from aftermarket and the amount of work is doable..
Sam
Old 01-18-2010, 12:55 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
I have yet to put on an aftermarket sheetmetal part that hasn't taken an extra day or two to tweek and repair. If you get the original fenders, weigh an original vs. the aftermarket. Huge difference.
Old 01-18-2010, 12:56 PM
Sam
I see what is accomplished on metalmeet and am humbled. There are some talented artisans on there.
Old 01-18-2010, 12:59 PM
I'm hoping he'll go for me using the original sheetmetal. He wanted to start with new metal so he knew it was rust free. The guys who started on the car sold him on that idea. Then the guy got overwhelmed and bailed on the project, left my buddy with an unfinished car. I bet I've pulled out one pound of shims from the front clip.
Old 01-18-2010, 06:38 PM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
About 4 years ago, my entire front clip,(including headlights), was stolen. After 4 years of looking at fiberglass parts and reproduction steel as well as finding some really honest users, I bought original parts. NONE of the people I spoke with said the aftermarket parts were truly "bolt on" perfect. All said they required some "massaging". Since I'm not a massager, I decided I'd rather spend the money and shipping on originals. Just my two cents.
Old 01-18-2010, 07:38 PM
1slow64's Avatar
I had the same problem with my 69. The aftermarket stuff is garbage. If I could have found a solid donor I would have used it.
Old 01-18-2010, 09:54 PM
Poor buggers who fall for that crap. I have seen people throwing away perfectly good OEM stuff because it isn't "perfect" to replace it with repro garbage, sad.
Old 01-18-2010, 10:44 PM
Aftermarket body parts are notorious for not fitting.
You just hope that it's something fixable with some shims and a die grinder.
Aftermarket Anti-lock Brakes?????? coda618 Suspension - Brakes - Steering 1 10-10-2008 11:14 AM
Need some math help.... sheetmetal cones Slomotion34 Body - Exterior 13 05-21-2008 12:00 AM
Aftermarket spring cups or let the springs rest on a shim? sizemoremk Engine 3 01-13-2006 03:51 PM
Aftermarket mustang sheetmetal 66StangBoy Body - Exterior 12 04-22-2005 05:12 PM
