Rare 396/375 or just another 396?
I'm a newbie and have a couple questions if someone could help.
I bought a 68 Camaro, well wife did for my 40th b-day, and was told it may be a rare L78? This is what the block numbers are saying: Date Code C26 8 - March 26, 2008 Cast #: 3955272 - 396/375 Stamp: T0414JH 19W79942 I have been fighting a miss and found a broken valve spring. Can't seem to find what spring to replace it with! They're double springs. Head Cast # 672292 From what I have found, these are from a 70's 402/454, Oval Port, Open Chamber, 2.06 intake, 1.72 exhaust and 110cc. Are these good heads for this motor? Are they degrading the performance? If I need to replace the heads, I will still need to replace the spring until I can get better heads. Still want to cruise around. I was told that the reason I had some bent rods and broken spring is because the motor is too much for the heads? Any suggestions? |
Dont know about the numbers, but the L78 had square port heads......4 bolt mains, forged crank and pistons.....
Ontario Rodders |
Most likely the engine has been replaced...Pull the heads have the valves done..new set of springs and pushrods and go have a good time..
Typically bent pushrods and broken springs come from overrevving the engine.. Sam
This number(19W79942) is a partial VIN
1= Chevrolet 9= 1969 W= the assembly plant 79942 should match the end of your VIN, but it probably wont, because your car is a '68, and Camaro's werent assembled at Willow Run Assembly(W). Somewhere along the line the motors been replaced. You'll want to look at your Body tag on the firewall or cowl and decode that to help figure out how your car was originally built. If the repairs make the car run good, drive it and enjoy it while you research its background. Edit: AAnd that casting date would be 1968. Are you sure that last digit is 8, not a 9. The JH code wasnt used for the 68 Camaro, but was for the 69 Camaros, Novas, for the 375/396. Looks like youve got a 1969 375/396 block, that was installed in a Nova on 4/14/69. Last edited by FmrStrtracer; 06-11-2012 at 11:56 PM. |
| 396? | scotttripp | Engine | 1 | 01-23-2012 07:08 PM |
| My 66 SS 396 | Springer | Hotrodding Basics | 9 | 04-16-2011 03:11 PM |
| Stock 70 Chevy 396 375 hp questions | beertracker | Engine | 7 | 01-11-2011 06:05 PM |
| Rare 65 Chevelle 396 4 bolt block | Fastest65 | Engine | 10 | 07-02-2008 09:37 AM |
| Is it a 396/350 or a 396/375 | hollywoodbob | Engine | 12 | 07-30-2003 10:51 AM |
