Rare 65 Chevelle 396 4 bolt block - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2008, 05:22 PM
Hey Guys,
I have a piece of gold, 396 casting 3855962.
I have been looking for the refrence to figure
out the stamped engine code numbers on the
right bank in front of the head on the block....
you know the flat area on the deck surface right in
front of the passenger head. it is "TII04EF" with a "B"
below the "F".
Help...Mortec doesn't help in this area.
Thank you
Old 06-30-2008, 06:27 PM
I found the "EF" suffix listed for a 360HP '66 396 w/3 or 4 speed.
The block casting # indicates '65 or '66 ,4 bolt, High Perf eng.
JA
Old 06-30-2008, 06:41 PM
JohnnYa 396 stampings
Hey thanks.
Yeah the 3855962 on Mortec says 65 only 4 bolt.
No option for 2 or 4 bolt , just says 4 bolt. And that
is what I have. "Hi Perf" is cast in about 3-4 different places.
Just wanted to know what the deck stamps meant.
Old 06-30-2008, 07:06 PM
SSedan64's Avatar
Originally Posted by Fastest65
Hey Guys,
below the "F".
Thank you
Nice find Fastest65, Here's 2 sites you can lookup Info.
http://www.chevymania.com/partsid/suffix.cfm?block=Big
Code-- Year-- CID---- Vehicle---- HP--- RPO--- Trans--- Carb-- Comments
EF----- 66--- 396-- Chevelle----- 360-- L-34-- 4-Spd--- 4-Brl-----------
EF----- 67--- 396-- Chevelle----- 350-- L-34-- 4-Spd--- 4-Brl------------
EF----- 68--- 396-- Chevelle----- 350-- L-34-- 4-Spd--- 4-Brl-----------
Casting Number-- CID-- Years-- HP--- Comments
3855962--------- 396--65-66--------- 4-Bolt
http://www.nastyz28.com/gm-chevy-cod...-suffix-13.php
CODE-- YEAR --- MODEL--- CID-- HP-- TRANS-- MISC
EF----- 1967--- Chevelle-- 396-- 350-- Mt---- HP
EF----- 1966--- Chevelle-- 396-- 360-- Mt---- HP
EF----- 1968--- Chevelle --396-- 350-- Mt---- HP
Old 06-30-2008, 07:11 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Thank you
Did you email the serial # to the fellow at Mortec? I did it once on a Friday night and got a response in a 1/2 hour.
Nice guy.
Old 06-30-2008, 09:11 PM
toecutter's Avatar
USMC....0331,DAD!
you wanna sell it??????
Old 06-30-2008, 10:38 PM
Have it checked and then hang onto it while you 'put it out there'. Just went through this crap looking for a correct date code etc 440 block for a numbers match Superbird that gained an inspection window while on a casual cruise. Somebody out there NEEDS your block, put it out there, you'll see.
Old 07-01-2008, 07:17 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
...inspection window...hehehe....that means there is a hole to look through....hahaha....in a mopar....ROFLMAO!!!
Old 07-01-2008, 10:50 AM
Rare 396 4 bolt block
Thanks for all the insight. I am keeping this
3855962 block I have. I do know where there
is another one though and it is a true 3855962
block, but the guy really wants a ton of money for it
A TON.!! it is all magged, brass frz plugs, crank, rod etc..
in plastic wrap $6500.
I picked mine up for a song and the guy I bought it from was
real cool and split the cost of magging it for cracks with me
before I bought it other wise I wasn't going to buy it. Now if I could
find a set of 3856208 rect port heads. these 396's don't compete
with all the new stuff out there 572's, 540's, 502's, 468's etc.., but I have had and have riden in some 396 car that would make ya crap your pants.
they were under rated on HP from the factory and with a solid lifters like
to houver around 6500 pretty easy and the HP goes from 375 to 425+
by just going from hyd to solid.
Old 07-01-2008, 09:28 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
Hey Guys,
below the "F".
Thank you
Are you sure it's not IF code? The 962 casting was 396/425 Corvette. First introduced in February 65. By the 66 model production they were using 427's and the left over 962 castings (396 blocks) were used in the Z-16 Chevelle's or sold over the counter. They made 211 Z-16 Chevelles and they were rated at 375 HP. You have a valuable block.
Old 07-02-2008, 10:37 AM
65-396 4 bolt 962-cast Thanks "1930u"
Hey there,
I looked again and it looks like "EF" not "IF" on the stamped area
on block deck pass side.
Looks like this
TII04EF
B
The "B" is below the "F" and to the right.
"Hi Perf" is cast all over the block like 5 or 6
places.
FIT 10 bolt 78 and 65 Alan Byers Suspension - Brakes - Steering 2 11-29-2007 05:49 PM
small block chevy crank bolt msod13 Engine 9 09-05-2007 05:47 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
64 and 65 chevelle hoods differences DougHerzog Body - Exterior 0 11-26-2002 02:43 PM
4 Bolt Block HotRodS10 Engine 16 05-21-2002 07:27 PM
