rat rod weight??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2005, 05:48 AM
New Member
rat rod weight???
anyone know the weight of the 29-32 ford pickups and/or coupes?
i've searched and couldn't find anything here or on google.
i know it can vary due to many factors, but i'm just curious if they are as light as i think they are (~2000 lbs). thanks guys.
Old 08-07-2005, 06:01 AM
cboy's Avatar
Last journal entry: Finished
Depends on if they are roadster, coupe, sedan, fenderless, hoodless, big blocked, small blocked, tranny etc. but most of the ones I've seen on the scales are more in the neighborhood of 2,700. My buddy's 29 coupe is 2,750 (fenderless) and my roadster (fenderless, hoodless, topless) is almost 2,700. BTW, if you pick up the Carrera (coil over shocks) catalog, they have a nice little tech section for estimating the weight of an early 30's car.
Dewey
Always learning...and sharing what I've learned.
Old 08-07-2005, 08:47 AM
New Member
thanks for the info.
to be a little more specific, how much do you think something like this weighs with a small block?
Old 08-07-2005, 09:40 AM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Oh thanks for posting that pic. Jimmy Shine has by FAR the best looking hot rod truck. That thing is a beauty!
Heres another pic
Mike
Old 08-07-2005, 09:49 AM
Eric Von Zipper's Avatar
Ole Skool Greaser
Oh joy joy me first post.
Even with my 600lb flathead my 30 5 window weighs under 1 ton.
Well until I put my fat *** in it.
Old 08-07-2005, 12:58 PM
New Member
cheers for giving me more info on that truck. all i was able to find was that little picture. that thing is drop dead gorgeous.
Old 08-07-2005, 03:27 PM
cboy's Avatar
E Von Z,
Have you actually had it on a scale (I'm not doubting you, just a little surprised)? That's quite a bit under the numbers I've seen. Anything peculiar about your 30 that would bring it in under a ton?
Dewey
Old 08-07-2005, 03:28 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
Might as well give you a bit more info then Jimmy Shine is an amazing craftsman, he's like the Midas of hotrodding, everything he touches is garaunteed to turn out amazing!
The truck is a '34 Ford, heres a pic to wet your whistle
That pic was taken at the El Mirage Saltflats.
He builds bikes mostly, old syle choppers, really traditional stuff.
Heres a pic of him and a drop-dead gorgeous bike
Most of his stuff he does for So Cal Speed Shop.
His website is
http://www.jimmyshine.com/
Mike
Old 08-07-2005, 07:37 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
*click, save as... click, save as...
Old 08-07-2005, 09:59 PM
Ole Skool Greaser
Originally Posted by cboy
E Von Z,
Dewey
Stripped to the bones:
Rear fenders bobbed, aint found fronts I like yet, no hood, running boards, interior, ( cept seat) single layer flooring, trunk is a box with battery and thats it. Oh yeah front and rear, and port hole glass only. Doors are bare inside. Stock firewall is gone, a single sheet of 16 gage replaced it. No heater, (dont need it) nor wipers. Body has been chopped and filled, sits right on the frame(no blocking)
Heck I didnt even paint it, just primer and sealer.
I can grab the body below the truck lid and pick it up and drag it about my shop. If I yank the flattie I can drag the front around also. 3 of us pick it up now and then, just because we can. (all 3 of us are over 250 lbs)
Old 06-10-2006, 04:26 PM
my home made 32 chevy roaster is 2400#.
Wanted: Rat rod definition Madd Syntst Hotrodders' Lounge 41 12-12-2011 04:32 AM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
tot rod mike c Hotrodders' Lounge 2 05-02-2007 12:40 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
Q-Jet Metering Rod Idea Silver_Camaro Engine 6 09-16-2003 01:48 PM
