ratchet rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2006, 09:50 PM
njbloodline666's Avatar
I Love VTec
ratchet rebuild
i would highly recommend not removing the "shifter" from your ratchet if you dont have to. getting that detent ball back in is a pain in the arse. i was wondering if you guys have any tricks to get it back in. i mean, i did it, it just took about an hour. seems too long for such a simple task. any tricks for future use? btw it was a matco ratchet if it makes any diffrence
Old 09-07-2006, 02:15 AM
Kevin45's Avatar
Just one of the guys
I did that to my Craftsman ratchets (junk BTW) because they always would slip a tooth and let you bust a knuckle. After swapping them out with Sears four times I though I would see what made them tick so I tore them apart. I pulled the spring to make it longer and it cured the problem on the ratchets. All three of them. BUT....it was a pain getting the detent ball back in. It probably took me a little less than an hour, but after the first one it went pretty well. A word of advice....do it inside of some kind of container like a shoebox that has some sides to it. When the ball or spring hits the floor, it is a good 30 minutes minimum trying to find them
Old 09-07-2006, 03:46 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Gee Kevin, if you only took about 30 minutes to find them, your garage must be very well lit and surgically clean. Do I need to come over and dirty it up a bit?
Use just a small dot of wheel bearing grease to help hold the ball. It worked for me, but I don't know if you are really supposed to do that.
In a while, Chet.
Old 09-07-2006, 04:14 PM
I Love VTec
yeah after spending about 20 mins looking for one i ended up taking apart a strut mount bearing lol now i have about 40 of them.
Carb rebuild - won't start now. Please help? joe99 Engine 6 11-30-2011 03:04 PM
C-4 65 Mustang Tranny Rebuild 65Mustang289HIPO Transmission - Rearend 13 05-02-2006 12:47 PM
Which rebuild kit? leastbay Engine 7 12-19-2004 03:19 PM
To rebuild or not to rebuild?? 68Impala Transmission - Rearend 1 05-01-2004 11:16 AM
To rebuild of not to rebuild pete379 Engine 7 04-19-2004 09:25 PM
