rating - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2007, 04:31 PM
rating
With 350 , 350 chev eng ,370 ,9 in ford rear end. what would be the best standard trans to use. Borgwarner t-10 , muncie m-22, or saginaw also 4 or five speed. Why
Old 02-13-2007, 04:55 PM
poncho62's Avatar
Wiki Edits: 5
I'd have a couple of choices, with those 3.70 rear gears..........The 5 speed for the overdrive on the highway. But, you may be sacrificing a bit of strength.
My other would be an M21 Muncie.........with the close ratio gears. An M22, or Saginaw has a pretty steep 1st gear, which with those gears you don't need.
T10 is pretty much the same as an M21
Old 02-13-2007, 05:12 PM
m-21 or t-10
thanks sounds good. you said 5 speed not as strong
Old 02-13-2007, 05:14 PM
poncho62's Avatar
Wiki Edits: 5
From my understanding, they are not. But I am not so much into the newer stuff
Old 02-14-2007, 06:59 AM
65 Imp SS's Avatar
Check out this site on 5 speed spec's http://www.richmondgear.com/01pdfs/pages25-27.pdf
Also correct me if I'm wrong I thought the m20 had the deeper 1st gear (2.52)and the m21,m22 had the same 2.20 1st gear with the m22 being the heavy duty model? http://www.5speeds.com/muncie2.htm
Old 02-15-2007, 11:39 PM
Saginaws could be had with one of four different gearsets. Low gears available were 2.54, 2.85, 3.11, and 3.50.
Muncie M-20 low gear was 2.52, M-21 & M-22 both had 2.20.
Borg-Warners ranged from 2.20 to 3.42.
I personally wouldn't use a 2.2 low gear with 3.70 gears because you'd have to slip the clutch excessively when starting off from a dead stop. I'd divide 9.5 by whatever axle ratio I had, and make that my low limit (numerically). And that's with 25.5" tires on a 3200# car. Adjust to a proportionally higher number if using taller tires or if the vehicle is heavy.
Old 02-16-2007, 05:18 AM
If you want to spend the $$$$$ a Tremec TKO600 will handle the power you mentioned and with a 3.70 rear gear will give a good low end punch and the OD will let you cruise easily at highway speeds..
JA
Rating Rear Ends cboy Transmission - Rearend 3 12-02-2006 03:08 PM
How does the CC rating work on headers? schuffman Engine 2 02-25-2006 02:01 PM
Horsepower Rating 350 Lepracaun Introduce Yourself 1 06-29-2004 06:10 PM
rochester 4gc carb cfm rating? starting over in min Engine 2 08-07-2003 07:03 PM
